The car in question is a Vauxhall Astra 1.6, 2001. This has a gearbox where you lift up a gear-lever collar to select reverse.
I have had a weird thing start happening on my car as of yesterday. I got to the end of a 60 mile drive, so everything was nice and warmed up. Stopped my car, put it into reverse, *CRUNCH*. It went into gear, without forcing it, but I wasn't being rough with it and it shouldn't be crunching.
After some experimentation I have found that after you have crunched it into reverse, if you put it back into neutral or any gear and then back into reversed WITHOUT releasing the clutch, then it doesn't crunch the second time you put it in reverse. However, if you put it in neutral, let the clutch out, then push the clutch in and select reverse again, it crunches.
If you are VERY gentle and slow with the gear change it seems to be fine, but even with just normal gentle pressure it will crunch into reverse.
The car had its 3 year service and MOT 1 week ago. No warning lights have come on and there are no other symptoms. Does anyone have any idea what could be causing this?
I am going to take it to the dealers tomorrow. Believe it or not, the warranty runs out as of today
So I will have to point out that it started at the weekend when they were shut. This is worrying me as I have to reverse park and I don't want to blow my gearbox up.
