gebrit duo fix frame
15 Jan 2007
Bristol
hi..im looking at fitting this system into a new bathroom..
is ok to box the complete system in?
ive been told that you can service through the flush plate!!!
Is this true?
or should i leave myself another way in.... eg an extra service panel?
any advise would be great
regards john
The Idea of the square flush plates is that you can service them all from the front. So boxing in is fine.
Yes they work fine. Make sure you securely bolt the top and bottom solidly. The supplied outlet is not the same standard we use as pan connectors here so I discard them and use Hep pan connectors.
