- Joined
- 14 Nov 2015
- Messages
- 2
- Reaction score
- 0
- Country
Hi all,
I'm looking at buying a house with a diagonal crack, ~1/4" up the external wall of the passageway between the 2 terraces.
The surveyor thought it was historic so shouldn't be an issue for mortgage. But I do want to tidy it up for resaleability, and before that get the leak fixed.
From the position of the crack over a manhole which has a big crack in the clay pipe it's obvious to me that leaking sewer is the cause. The sewer was adopted by Severn Trent Water in 2011.
STW sent out their inspection guys yesterday, they agreed theres a crack in the manhole, the pipes look ok on the cctv but they'll clean them & redo the cctv. The STW guys said that STW usually do a risk assessment matrix to assess whether repair work is required, but in their experience they said STW wouldn't normally repair a cracked pipe unless it's leaking into a property or overflowing.
This seems quite lax given the trouble we go to pressure testing pipes on new installations.
Does anyone have any experience of getting water companies to fix sewers? How much 'encouragement' do they need - surveyors report confirming cause & effect? Solicitors letter threatening legal action?
WIth regards tidying up, I'm redoing the groundfloor bathroom on the inside, I'm minded to underpin the foundations & rebuild the wall certainly the outer leaf, supporting whats above with acros. I figure I've effectively done the same thing structurally before supporting double doors widths with acros to put lintels in.
Thanks in advice for any advice!
PS I'm new to this forum, let me know if I breach any etiquette!
