gledhill boilermate fe 180
20 Jan 2008
Suffolk
drained water from boilermate drain tap to fill with inhibitor
found ballcock in the f&e cistern works ok but water wil not flow from f&e
cistern to main tank below blocked? but pushed small pipe from f&e cistern around 15mm elbow in to tank below so were is it blocked,
have filled it from the 22mm expanion pipe on the other side .
has some person have info thank you
