Gledhill Boilermate OV A Class - OV = Operation variable!!
  • Thread starter Thread starter 13
  • Start date Start date
One problem turns to another! Aargh.
OK thanks for your input, I think I will raise a complaint with NHBC to see if that gets me anywhere then failing that will look for a good plumber and get ready to empty my piggy bank :cry:
thanks again
you do have a point, depends if the water will run hot downstairs for a long period, not just a small amount.
This will be to late for you but it could be that the hot and cold pressures are set slightly different and the cold is passing back down the hot . The pressure of hot and cold have to be set the same
