Glow Worm 30 cxi leaking, please help....
It will either be an olive in there, or a fibre washer. As long as you have the tools to get to it properly it should be a simple fix for you.
Don't know this boiler intimately enough to say for sure what it is in this joint.
Thanks for the reply. What steps do I need to take to be able to undo the joint like what do I need to turn off or flush out? Thanks
Assuming it is the cold mains inlet, just turn this off under the boiler and open a hot tap to release the pressure.
Have an old towel handy to catch the drips and don't let any water drip onto anything remotely electrical :wink:
im pretty sure thats a fibre washer connection. if your carefull you could probly get away with giviing i a little nip up.
Strange also that you still have the old style condensate trap on your boiler as well.
The blue cap will spilt and leak.
A new version has been available for a while now.
if you can get the manual its a straight forward job. the blue cap just unscrews off and on again but turn of the electrics and put a small bowl underneath to catch and condense.
if you dont feel totally confident in starting the repair, theres nothing wrong with getting someone who is. :)
Cheers Gavinda, it's not that I don't feel confident. I just don't want to blow the house up :oops:
The blue cap thing seems easy enough, the black thing that houses the water filter at the front of the picture is another matter..
