Help!, please...
...I have just moved into a property which has a 30cxi.
It provides domestic hot water just fine, but...
...I now want central heating; turning the programmer to constant; nothing, even with the c/heating thermostat turned fully closed.
Something else is odd; the circulating pump operates when the boiler fires for hot water; and stops a few moments after the gas to the burners is turned off?
Phoned GW tech support; was told that this was not a known problem & that I would need a service.
Any ideas?
I am happy/competent to change the PCB if this is the most likely fault. They seem to cost about £40 on ebay (where I got them for Pottertons on previous houses).
Jan
Any ideas?
Jan
