- Joined
- 19 Mar 2023
- Messages
- 2
- Reaction score
- 1
- Country
I have just moved into a property with a Glow Worm 7 25s. It doesn't seem to operate like the videos online or manual says. For example, it won't let me change the Hot Water Temp. and I can't get it to ECO mode. I CAN change the heating temp.
Underneath the boiler is a panel with 2 switches the top for Hot Water which you can set to timed, once & constant. The second for Heating with the same options, timed, once & constant.
In a cupboard we have a water tank with an electric switch on the wall, which is in the off position (which I assume is an immersion heater?) and on the actual boiler is a temperature gauge. we have it set to 70degrees.
We only want the hot water at the moment, no heating. On the Glow Worm I have pressed the mode button so it just shows the tap icon. On the panel beneath I have pushed the switch along to 'Constant'. Water tank settings have stayed the same as written above.
This morning we had no hot water. However if I put the Glow Worm back to showing the Tap and Radiator icon, the hot water comes through. The downside to this is that whilst the radiator icon is showing on the panel, the boiler is constantly running, even when we are not* pulling water.
We do have a thermostat on the wall in the hall, it is showing 15degrees. However the radiators do not get hot as the panel under the boiler is switched off for heating. Can anyone please help decipher this, its a complete mystery to us. Thank you for any help
