- Joined
- 19 Jan 2008
- Messages
- 15
- Reaction score
- 0
- Country
Hi all i'm after some quick help i have a glow worm compact 100e that's got a problem but i'm not sure how to solve it. The problem is the boiler works for a while and then the boiler gets to temperture and switches the gas off as normal, the problem then arises in that when it wants to switch the heat back on it can't the igniter does nothing. you can still hear the pump running the hot water and heating at this point doesn't work if you then switch the dial to the off position and wait until the pump has stoped can somtimes take a while then swicth the heat back on it works fine the water also works at this point.
I don't think it's a problem with the igniter because when i try and get it working after the pump has stoped it works fine no problem. what other protential things could it be. I'm begining to feel like it could be the pcb and one of the resistors if this could cause this i can get on of the guys at work to change components on the board is this a likely suspect
Many Thankd
Dan
Many Thankd
Dan
