I cant find the filling loop on this combi does anyone know where it might be i have check almost every where but i am unable to locate it. Does anyone know where it could be.
Ihave looked under the boiler but no connections i found the flex connection pipe on top off the boiler i took the bath panel off to see if it was in their but no joy so the only place i can think it might be is under the floor boards or the fitters have not put the connections on the pipe work.
i have looked at the manual and according to these the filling loop is on the heating flow rather than the heating return is this correct on this model.
