GLOW WORM COMPACT
  • Thread starter Thread starter BOB..DOLE
  • Start date Start date
B
BOB..DOLE
I cant find the filling loop on this combi does anyone know where it might be i have check almost every where but i am unable to locate it. Does anyone know where it could be.
There is no filling loop on the boiler. It must be fitted on the pipework to the boiler. We usually fit them below the boiler for easy access.
Just loop for a flexible connection between two pipes.
Ihave looked under the boiler but no connections i found the flex connection pipe on top off the boiler i took the bath panel off to see if it was in their but no joy so the only place i can think it might be is under the floor boards or the fitters have not put the connections on the pipe work.
i have looked at the manual and according to these the filling loop is on the heating flow rather than the heating return is this correct on this model.
Not tank fed, is it?
No reason FL shouldn't be on the flow. Arison mffi's internal loop is on the flow, eg.
Saves chilling a hot hex.
if so how did they fill the system :?: :?:
i have known the loop to be in a bedroom
the boiler was in the kitchen a floor and opposite side of the house away :twisted: :twisted:
