- Joined
- 24 Nov 2017
- Messages
- 69
- Reaction score
- 6
- Country
Just when you think you've seen enough Hive instalation threads and then this pops up!
I've searched the forum for similar threads, but most seem simple in comparison.
Current setup is a Glow Worm Flexicom 30CX with a Climapro Wireless Handheld Thermostat programmer. The wire that goes to this is the black two core flex to the left in the photo.
My initial thoughts are that I need to take another live from L to 1 on the Hive back plate and another from R to 3 on the Hive back plate.
But the question is, do I need to remove the bridge (red cable going from 24v to 0v) when I remove the black flex from the connector box?
Also, F is for frost stat - will it run using the Hive as a frost stat or will I need to add an extra stat?
Thanks in advance!
Thanks in advance!
