glow worm ultimate 50ff not starting
16 Sep 2008
Worcestershire
Hello,
Just come back from a few weeks holiday and went to warm up the water but the boiler wont light.... I can hear the fan and the pump and I can see the 'spark' activating, but the pilot light wont light? The ignition spark just keeps on 'sparking', but no pilot light.
Does anybody have any ideas please??
Thanks in anticipation!
Rob
Did you turn the gas off when you went on holiday?
If not sounds like you need a RGI in to check over gas valve.
Is it lpg?, does it have the blue double solenoid cover under the gas valve?. Not a million miles from you if you need someone to cast an eye over it.
probably blocked pilot, very common on this boiler. RGI job though I'm afraid.
Hello again,
Many many thanks for the quick responses.
We were away for just over 3 weeks, and the gas was not turned off, should it have been??
It isn't lpg, and it doesn't have a blue double solenoid cover. Also, thanks for the offer to take a quick look 'ollski', but I didn't realise that my wife contacted a Corgi registered guy today and he's going to be calling tomorrow...........hope it doesn't cost me the earth!!
Once again I really appreciate the input from you all,
Rob
There aren't many faults on these tbh, fan stopping and starting - pcb, sparking with no spark in window - electrode lead shorting, spark in window no ignition - gas valve solenoid / blocked pilot. Covers 9/10 faults on these.
