Glow worm ultimate
26 Mar 2006
Wiltshire
Hi
Any ideas?
My boiler pilot is on and the fan works ok, but it will not fire up
There is a continuous ticking as the electrode keeps sparking
Help please
I find the spark electrode lead gets worn as it passes throught the case of the boiler and arcs there rather than at the pilot assemby
unfortunatly you will need to remove the case by undoing both the butterfly and small nut just above where the boiler stat is and then pull the bottom of the case towards you and then lift it up of the top of the boiler to check it and that is a CORGI job
but if you can see the spark inside the boiler then it isnt this, its probably the gas valve and that REALLY is a corgi jobbie
The last three that I have been to have all had the same problem!
The electrode lead was not correctly placed when the cover was fitted and was arcing to earth.
Tony
P.c.b. , not sensing pilot flame .Flame on pilot could be too low , poor earth connection can also give this symptom . Is the polarity to boiler correct ? Normally , the fault as you describe can be rectified , by renewal of the p.c.b. I would recommend you employ the service of a c.o.r.g.i. engineer , with experience of this model .
Tony
same here tony I lurvve that fault
:LOL:
mikey boy is right (if you can see the flame that is)
