Doesn't sound like your boiler is firing up at all. If it was ,the heat created would be going somewhere,if only a short way through the flow pipework.
Since the problem started, but whilst it was still turning on, how long did it run for. Did it stay on for more than a few minutes, or just a few seconds?
The manual refers to four neon lights which you can use to help with basic fault finding.
My daughter had a Glowworm Ultimate 50 and I managed to keep it going for her over the last 5 years, 2 refurbished PCB, ignition electrode, air pressure switch plus a number of other components external to the boiler.
It had been in since the house was built around 20 years ago and was one problem after another.
Finally realised I was throwing good money down the drain and replaced it with a Vaillant System boiler (7 years warranty) , also replaced the old Siemens controls with a Hive and renewed all the radiators for her.
