Hi Folks I have a glow worm clearly solar heating system fitted but I've noticed that the fluid is running down to slates would this be coming from a connector or the panel they've been on the roof for a few years now.
One thing that would be checked on a service is the expansion vessel. Was that checked when it was "looked at"? Could be that it has failed and your relief valve is discharging onto the roof
The automatic air separator should be fitted on the return pipework, between the solar pump and the cylinder, but have seen some wrongly installed at the top of the collector panels, is yours fitted correctly ?
