do you think someone had a really bad experience with a gas engineer once so went out and designed the condensate trap for a glowworm cxi to get his own back. god i hate that man. or woman, it probably was a woman. maybe she designed the ideal isar too.
its can be a **** to get out, plus they block up with sh1te and the holes are so teeny. and as you say the cap always leaks onto the plate heat ex. i wonder how many of them have been changed cos of it
I have not had cxi trap splitting. I have not come across any other boiler with the same kind of workings as a cxi has ( I have not seen all boiler traps ) The cxi has a float in the trap that drops and blocks off the discharge point after releasing condensate. This float stops the boiler using the trap as flue. The float gets dirty and often sticks to the bottom of the trap causing the codensate to back up into the boiler.
The idea of the Glowworm condensate trap is to release condensate in 'pulses' rather than as continuous drips all the time the boiler is on. Reason: to prevent the condensate line from freezing.
Trouble is, once the beastly float thing is stuck to the outlet with a load of condensate sitting on top of it, there's nothing short of blowing vigorously up the condense drain that will release it!
I've come across a CXI boiler still running with the bottom third of the combustion chamber full of water with it leaking out of the sight-glass!
Another CXI oddity was a reported leak from underneath the boiler but when I got there - no trace. When I got it open there was a suspicious looking 'tide-mark' all the way around the bottom of the casing but evidently whatever had blocked the trap had 'gone away' by itself!
