Gluing to insulated plasterboard
10 Dec 2018
What's adhesives can be used to glue to the insulation foam used in insulated plasterboard?
I've insulated a small wall which has a small window in, however the insulation board has thus created a small window ledge which i need to cover with something. I was going to just stick a wooden panel there, but it cant be mechanically fixed to the foam so will need to be glued, however adhesives like pink grip are clearly not going to work, as the part of the board exposed is the inner foam bit.
