Going Wireless
31 Oct 2008
Lancashire
Hi all,
What is the easiest way for me to change to a wireless stat/timer.
At present I have the boiler in the utility room, the timer in the airing cupboard ( Honeywell ST7199 ) and the standard rotary Honeywell stat in the hall but near the airing cupboard.
there's no easy or hard way, needs a receiver unit which req's a 240v feed, along with a switch live and common from your boiler (use instuctions to find where external controls connect, prob be where the time clock switch live connects into the boiler)
Then the prog/stat needs configoring following instructions given with it.
Prob easy for you to have the reciever unit next to the boiler, use five core cable, live, neutrel, earth for reciever, and other two wires for common and switch live.
I use Drayton RF2's.
