G
Goldspoon
Any advice gratefully received!
I am fitting a WC, basin and bath. Fast flow shower is also required (I can buy whatever shower is reqd.) and I am wondering best way to go.
Head of water is only about 1.5m and another shower on same floor is pretty useless. Pipework in bathroom is 22mm for cold and hot (both gravity). Cylinder is next floor down and a way away (so cannot easily take water direct to a pump using a flange due to pipe routing issues). Also no easy way of adding a new pipe to the water cistern.
Q: I could fit a shower with a built in pump... are they any good?
Q: I could fit a pump within the bathroom (pump that boosts hot and cold) but I suppose this might not be a good idea as reading up on this suggests that pump should be close to cylinder... is this a feasible way to go?
Q: If fitting a pump close to cylinder presumably one can fit one pump that does cold and another that does hot... or one pump that does both? Problem here is that whatever I would do would mean the pump coming on for everything (hot water taps and shower, cold water taps and shower)... or is that a problem?
Q: I am also presuming cold water cistern has to be large (50L?).
Q: What about cylinder? What special requirements here?
Last Q!: 22mm pipes (actually 3/4 inch) have iso valves on ends at moment (first fix). Presumably this is not a good idea as they are a bottleneck due to being narrow inside?
Thanks in advance!
Thanks in advance!
