Grant Vortex 26e low pressure
22 Feb 2006
But it isn't! The low pressure LED's flashing but water pressure is steady at one bar. No CH or hot water. Is there a pressure switch somewhere?
Grant register installer here.
Simple answer link pressure swith out they haven't been fitted to new Grant combi's for several years.
We remove them every time we find them mostly because when your working on boiler they are renown for snapping off!
From memory the pressure switch connections are 15 and 16 on board just take out pressure switch connections and insert link.
If that don't do it it's the board.
Absolutely take wires out of board replace with link
If you do any work on system and have to drain or even just get rid of pressure that's time to remove switch.
It's threaded 1/4 bsp so you just need a 1/4 plug.
