Grant Vortex boiler sounds - desperate help
29 Nov 2026
Hi all,
I found this website out of desperation. I have an intermittent noise from my Grant Vortex oil boiler which is now keeping us up at night.
Its 18 months old. Fitted April 2025.
We never had this issue with the previous boiler it replaced (10-12 years old).
It seems to happen more in Autumn and Winter months, though maybe this is more noticeable as its on more frequently.
It’s intermittent. And it NEVER happens when an engineer is round to visit. The installers came on Friday morning and it was fine for the previous 24-48 hours. It was also fine until early hours of this morning until the noises started at 5am and woke me up.
I can’t seem to attach a video of sound recordings here to see if anyone has heard similar before. Its like a budgie and when it starts its constant. It happens shortly after the flame appears to fire up. When you take the front case off the boiler it is definitely coming from inside.
We’re at a loss right now and Grant are reluctant to come out as they can’t see what the issue would be from my description, and would only charge me and hand me to my installers; who never turn up when it happens!
Any help or steer would be greatly appreciated!
Here is a link to an uploaded video if anyone can listen in time:
It expires on Monday around 0730am but I can upload again if need be.
O-er, I'm a Grant owner but no engineer, but there are some good folks on here who'll chip in. Sounds metallic. Loose baffle maybe.
Thank you. If the baffle was loose would it still be intermittent based on current temperatures/pressures? It doesn’t seem to make this noise all the time, just usually at anti social times like evening and nights and when the days are colder (unless it does at other times and we just don’t notice it, but we don’t have the heating on too much).
Just to add: I have 10 year warranty as the installer is Grant accredited. Its been serviced by them yearly, too. They’re not sure what to check since it never makes the noise when they come over, and Grant say they’ll charge xyz and probably revert us to our installers if they can’t identify it either. Am at a bit of a loss tbh.
Sounds to be from burner possibilities in order.
Oil pump first call, may even be not correctly aligned to motor.
Fan catches when burner warm.
Motor bearings though they normally stop burner in one position.
Is the heating pump near to boiler or in boiler casing?
the heating pump is a Grundfos UPS3 and its on 1st floor directly above the boiler. It was on speed 3 but I turned it down to 2 today in case that was too strong for the system (?)
The heating pump was installed the same time as the new boiler and new cylinder. Otherwise all the pipework is the same
Would these explain why it only makes this noise at cold or when heating up? Sorry, I’m not an expert at all so trying to learn at the same time as problem solve this.
If its oil pump probably gets quieter as it warms up.
It's rare but oil pumps do fail we have changed probably a couple under warranty.
As noise is worst when it's cold that's how boiler should be at your engineers next visit.
