Green felt or foam sheets underlay
27 Jan 2011
UK
It will be for laminate floor in a bedroom and the floor now is floorboards that are not completely flat.
The laminate will be 8mm. I already have fibre board that I took up from the same room directly under the bedroom and have kept it for 5 years thinking I will use it in the bedroom one day. It is the older 7mm stuff and am trying to keep the height down as much as I can.
So Its now that day but now I have seen in wickes 5mm foam sheets and thinking they may be better. Lightweight thinner and not as messy as that green fibre.
The foam sheets were not around when I last layed a laminate floor so have no experiance with them.
The floor will have a 3.5m run of ikea pax floor to ceiling wardrobes along one wall which are heavy.
More info on the floorboards condition, 1960s some have been up twice for central heating - screwed down - split - repaired, some are cupped others are scoped but none really badly and can only tell if you run your hands across.
Is it solid foam or squishy foam?
I bought a squishy underlay for a laminate in a bedroom and the legs of the bed have sunk in a bit. I should have used the green stuff.
Maybe your bed get more ‘use’
Update on this, I used the foam sheets and they were great to use. I only layed one row at a time as needed so I wasn't kneeling and walking all over them. Nice to work with and easy to cut. I just used gaffer tape to to join and I only use short peices ot tape - just enough to hold the boards in place as I worked. I also staggered the boards.
Time will only tell how well they perform.
