@Johnmdc You legend! I did as requested, and the green light appears!!!!!! Thank you so much.....(slightly paro that it may disappear whilst the switch is on to heat water!).....will keep you posted! Thanks again!
@AGAS A British Gas engineer came over thismorning, and found out that the radiator and hot water temp gauge dials on the actual Boiler (which has become redundant due to the water temp being controlled on the Megaflow and the radiator temp being controlled separately) were causing a fault, therefore has he disconnected the two dials and it seems like everything is working fine now!.............Strange.....
