Greenstar 38CDi Classic over pressure
3 Jul 2017
Hello all, please help with a strange issue...
Been away for 2 weeks and when I returned, I checked the boiler as I always do. and the gauge was in the red. Bleed some water out to bring it back to normal. But how did this happen. I usually leave the key in the locked position. do you think that somehow water managed to slowly pressurise the system?
I have now taken out the key, will this stop this happening? if it was the case?
Thanks in advance.
Read more: https://www.diynot.com/diy/conversations/add#ixzz5rP0iqRuk
Always remove the key, if it still over pressurizes the Plate heat exchanger has probably pinholed
Hi Ian thanks for your quick reply, the boiler is still under warranty and is less than 3 years old. I just called customer service and they said that this sometimes happen depending on air pressure and temperature !!
They also said they would not send out an engineer for this....so I guess I will just have to keep an eye on it
Many thanks for you help.
If you remove the key and it still over pressurises get them out, they will change the plate under warranty, the good thing about a warranty call from worcester is that their engineer loses his bonus if there is a recall so he/she will change anything that is slightly suspect to protect their bonus, I had the exact same scenario a few months back and called it in for my customer and the lad nearly re-built the boiler
Now that it's over pressurised you should check the safety valve pipe isn't dripping...
Ian/Gasguru
Thanks for your reply, having removed the key yesterday, it appears that there is a constant drip, about a cup full overnight. Have checked the tap is fully off. Is this Ok? shall I put the key back in? or is this the source of the overpressure? Do you think this is worthy of a call out?
Thanks guys
yes call them out just say that when you remove the charging key that there is a constant drip with the valve fully closed and when they turn up tell them that if you leave the key in it over pressurises
Thanks all for the help, have now got a call out for tomorrow. I will let you know the outcome.
Thanks again for the excellent advise.
Hello Guys
Had a call out and he changed the fill valve assembly, apparently it was slowly filling up the system. All seems fine now. He recommended leaving the key in.
Thanks for your help, lets hope no more emergencies....
