- Joined
- 22 Nov 2019
- Messages
- 3
- Reaction score
- 1
- Country
Hi there
my contractor has just a few more things to finish off on a new bathroom we’ve had fitted. He left today and showed me the grohe smartcontrol concealed mixer was installed and working (https://pro.grohe.com/uk/34498/show...roduct=29149-G460&color=000&material=29149000). However the temp setting looked all the way to the left (hot end of the scale) and when I switched on an outlet it was approx 30C. It was late and he left saying nothing much could be done and it was due to the mixer so I took the trim off and dismantled the unit as far as I could without turning off the water and can see the issue: The mixer adjustment knob could barely go any more anti-clockwise - about 10 degrees rotation until it stops and the water becomes scolding hot but any clockwise rotation (about 20 degrees off that limit) it is already extremely cold. The knob can rotate at least another 2 complete rotations clockwise but obviously it just stays very cold.
I have a combi boiler (vail ecotec plus 831 I think) and very high mains water pressure (I live in a 4th floor flat and it’s pumped)- last plumber that tried to measure it got very wet and said it was off the scale. I have a different concealed thermo shower mixer in my other bathroom that works perfectly and didn’t expect this to be different. I want the middle setting to be 38 as recommended- my other mixer can handle it why not this one?
Could I do with a pressure reduction valve? Or is uneven hot/cold pressures? Or could it be a faulty valve?
thanks a lot
James
thanks a lot
James
