Grohe Tap Tails issue
24 Nov 2007
Near Lincoln
Just bought a Grohe Kitchen tap. The description states 1/2" BSP tails but measuring across the connector they're 7/8". I'm struggling to find a male connector from a 15mm pipe, any suggestions please? Really helpful guy in local Screwfix was stumped.
The nominal size of BSP threads bears little relation to the actual measurements.
They're definitely not 3/8" I'll have to visit a plumb merchant I think. I'n replacing a Franke tap that has different sized tails which has caused the issue.
Have you got any isolation valves on the supply pipes to tap ? The thread will be 1/2 inch BSP on your new tap tails. The thread size has nowt to do with the diameter.
The Grohe install leaflet has both 1/2 inch or 3/8 inch mentioned.... The leaflet has a vague 24mm (? the across flats of the nut?) on one diagram.
https://www.grohe.co.uk/en_gb/ambi-two-handle-sink-mixer-1-2-30189000.html only mentions the 1/2 inch and an adapter for 'continental use'.
Pics of the Franke tails and pipe connections plus the Grohe as well would likely be of some help - with a ruler for scale, perhaps?
The 1/2" BSP fit thanks (should have believed the spec!). Anyway thats sorted and will use the push fit on both sides which will make for easier fitting as I can attach them to the tails before fitting them and save messing with spanners in a confined space.
To expand on my earlier comment, my understanding is that BSP sizes were based on old-fassioned iron pipes. Such pipes were measured by a nominal internal diameter and the thread was cut into the outside of the pipe. So the actual size is a lot bigger than the nominal size.
1/2 inch BSP is the same size as the compression nuts on 15mm compression fittings.
