Grout removal tool damages tiles
9 Jun 2014
Yorkshire
I have had some help on my kitchen and the guy was scraping down the grout line, but i didn't notice he was coming out and scraping onto the limestone tile.
So i have lots of little scratch marks on my tiles now. You need to really look at the tiles to see them, but there are plenty.
I cant replace the floor and i was using this guy as general labour and so i have no comeback on him.
Its a case of just making do.
I need to clean the tiles before grouting and after grouting i will reseal. Do you know if these marks will disappear with new sealer ?
Put a little bit of sealer on now on one scratch to find out. Not much point in grouting and sealing if they will just show up.
as said above, try a bit sealer first, should that fail then you do have another option available to you cheaper than replacing a limestone floor, Buy some Honing powder, I use these guys http://www.ebaystores.co.uk/tilingl...97631?LH_Title=0&submit= &_nkw=honing+powder&, hire an industrial buffer, and you should be able to polish the scratches out, then grout and seal. hope this is of some help to you mate, I normally do a lot of terrazzo repair work so I know this method works, and can be done by pretty much anyone, you are not using a diamond floor grinding machine ;-)
as said above, try a bit sealer first, should that fail then you do have another option available to you cheaper than replacing a limestone floor, Buy some Honing powder, I use these guys http://www.ebaystores.co.uk/tilinglogistics__W0QQ_sidZ48597631?LH_Title=0&submit= &_nkw=honing+powder&, hire an industrial buffer, and you should be able to polish the scratches out, then grout and seal. hope this is of some help to you mate, I normally do a lot of terrazzo repair work so I know this method works, and can be done by pretty much anyone, you are not using a diamond floor grinding machine ;)
Thanks very much. This looks the way to go. I will try a bit of sealer first and see how it looks though.
