Grout
SMG
31 Oct 2007
Manchester
Hi, no your not going to successfully colour the grout afterwards i'm afraid. its a rake out and regrout job.
If your fed up with staining, cleaning it up and sealing the grout could be an option
If it wasn't flexi grout I'd just scrap the top layer off with a Stanley knife then treat with hg mould spray then re grout over the top again with fresh grout you would need to use the same palace white grout to make sure same colour and shade as before maybe try dye the grout with some food colouring after to try take away the whit co for water downed black food colouring see if that works, if not it's a oscillating saw with tile rake blade and then re grouting of them with colour of choice
I'd say best bet then is oscillating saw with grout rake then re grout bit time consuming tho, but easier with the saw than by hand, plus I'd still try food colouring just make sure use gloves and tooth brush and just try a wee patch test first before cracking on
If it's mosaic on the wet floor your best bets the dye but defo patch test it first, white grout never should be used on a floor and if it is best to seal afterwards if u try the dye let me know how u get on with it but think that's your best bet
Thanks, the tile is a rough sand faced tile, & the white grout will be very difficult to remove, I did think I could remove most of it, use the colourant, then re grout with the grey grout
I'd try cleaning it with suger soap and a fine sanding sponge it won't damage the rough porcelain tile then just try dying the exciting grout with the dye first
