Hello,
We've just had one of these babies installed along with a new Vaillant combi boiler: previously we had two tanks and a shower pump with a standard non-condensing boiler. The new system looks very impressive.
With the old system when you turned on the hot tap the pump would kick in and you'd get a steady stream of hot water. With this one however the hot water comes out at medium pressure, then the Grundfos kicks in to give high pressure, and then it stops and the pressure goes back to what it was, then it kicks in again, repeat. The temperature fluctuates with the pressure change, it going cold for a bit as the pump kicks in.
Anyone know what the problem is here? Do I need to change the settings on the boiler or Grundfos unit? Or is this not right at all and should I call the plumbers back in?
Andrew
Andrew
