Hi There
I wonder if anyone can help me please? I have recently had a Grundfos Home Booster installed to supply boosted water to hot and cold services via the integral tank and a Range Tribune 250l pressure cylinder.
I have set the outlet pressure at 3.0 bar to match the existing regulating valves in the system, with the differential set at 1.0 bar.
Unfortunately the system pump continually cuts in and out instead of running continuously when an outlet is opened or shower used. Not conducive to long pump life!
The unit has 28mm outlet pipework splitting into two 22mm legs, one to the Tribune, the other to the CWDS.
Any help gratefully received!
