I have a Grundfos Home Booster fitted (the inbuilt pump and tank solution), and if I put the high pressure above 3.6bar the pump keeps going, almost as if it's trying hard to increase the pressure. If I keep it at 3.5 bar with a 2 bar differential then it behaves correctly. I'd like to increase the pressure to hopefully get a bit more flow rate to a shower which is quite far.
Do I have it set up correctly with these settings, or should it indeed be able to get above 3.6bar? I can't see any leaks in the pipework
thanks
thanks
