Hi there,
I have a bit of an issue with my heating system and I'd be grateful if someone could help out...
Basically I have a Grundfos MK11 pump which leads into a Tower 2 port zone value. The issue that I have is that there seems to be a bit of a leak coming out of a small gold screw type thing on the part which connects to the pipe running down to the zone valve. In order to stop the leak I tightened this screw up with an allen key and the water stopped coming out. This however has seemed to cause a problem with the heating in that the radiators don't heat up. If I loosen this screw up again water starts coming out.
Does anyone have any ideas about what's wrong?
Thanks,
Mark
Thanks,
Mark
