A daft question perhaps but as someone who has no plumbing skills I'm turning to you lovely people (again) for some advice.
My old Grundfos domestic water pump that lives in the airing cupboard gave up the ghost a couple of days ago, leaking due to being corroded around the pump valves.
I had emergency cover for leaking pipes but not for the central heating/boiler but the chap that came out kindly fitted two new brass union gate pump valves in the same position as the old ones, so that theoretically I could go out and buy a new pump and fit it myself.
Went out today and bought a replacement Grundfos pump but its 15mm shorter port to port than my old one - and looking at all the new Grundfos pumps it seems they are all 130mm port to port leaving me with a 15mm gap between the two valves.
My question is this - is there any kind of coupler/extender/adapter/whatever you want to call it that i can fit to the top valve or any other way of bridging the 15mm gap to avoid having to fit a longer pipe?
Appreciate it may be easier to call out a plumber but thinking if this is a couple of quid fix i can get my hot water and central heating back on rather than having to call out a plumber after the bank holiday.
Many thanks in advance.
Dave
Dave
