GU10 Bulbs - Halogen or LED?
29 Jun 2006
Birmingham
Fitted some spotlights recently in the kitchen and not happy with the shadows they create. I've got 6 in a room sized 3x3.5m. The bulbs I have are 36 degree 50W GU10 mains.
I have seen some LED versions on the net made up of SMD's which I know are bright but has anyone here used them or offer me some advice please?
The shadows are caused by the design of the light fittings. The type of lamp fitted will make little difference.
They are called 'spotlights' for a reason.
CFLs will give a much better beam angle. But far better would be a fitting designed for PL lamps. I have 52 watts worth in my kitchen, plenty of light, no shadows. Far better illumination than 400 watts of halogen.
Not necessarily - I replaced 5x 50W halogen GU10s with these LED bulbs in my 2.4x2m bathroom...
http://www.ultraleds.co.uk/u1042ww-gu10-wide-angle-warm-white-p-2248.html
Before I had a shadow line about 18" around the top of the wall, but with these 120 degree beam angle LEDs, the shadow line is only around 6" down the wall, and so much more diffuse and gradual that it's hard to notice and totally inoffensive. Overall lighting of the room is much more diffuse and even. The warm white colour is close to the halogens, and in fact I prefer it now and find halogens too yellow! Brightness is a little less than the halogens but still illuminates the room fine - the old halogens were a little too much to be honest. With the bigger room and only one more fitting, the OP might be better considering the 5W version on that site which wasn't available when I bought my 4W ones. One of mine came with two dead LEDs but I couldn't be bothered to get it replaced. The fact the rest still work indicates they are connected individually in a parallel array which is good. Very happy with them. 250W ==> 20W and nicer lighting.
