GU10 downlights
20 Jun 2017
Hi all,
Just a quick one has anyone come across/used the ovia flameguard gu10 downlights? They look decent but only seem to be available online and can't find much info about them.
I know jcc fireguard seems to be the default answer for gu10 downlights but I've become not so keen on them, quite awkward to remove the bezel to change the gu10 lamp so it looks like people are pulling the whole fitting down a bit to be able to remove the bezel which ends up knackering the ceiling. Or any other recommendations for gu10 downlights where its easy to change the lamp would be appreciated cheers!
know exactly what you mean about the jcc bezels mate, seen so many ripped ceilings from people wrestling with them trying to swap a blown bulb. ovia fittings are actually decent quality for the price and the twist lock on the bezel is a lot smoother. aurora enlite e5/e8 or click inceptor are also pretty solid alternatives that don't tear your plasterboard apart every time you need a lamp change.
Cheers guys will definitely be giving them a try, and yes the price definitely did make me wonder!
