Guess the fault
9 Oct 2006
Essex
Vacuum cleaner tripping RCD
Vacuum cleaner is double insulated.
Neutral earth fault.
Where the neutral has gone down to earth on a PME supply there is no current flow to earth until there is a load on the circuit.
Does same happen when something else big is plugged in?
Neutral connected to earth pin fault didn't show until after new CU had been installed
