Hi, I own a java recessed Bristan shower and due to a leak from the front of the shower we contacted Bristan who advised that the cartridge probably needed changing.
Following a lot of reading (there are a few threads on this forum) we were sent a replacement cartridge free of charge and I managed (having removed the shower body from the wall) to remove the old cartridge and fit the replacement.
Problem is the new cartridge will only run cold. I've checked the flow (isolated the cold supply left the hot partially open at an isolation valve) and red hot water will come through to the recessed shower body. I've therefore assumed (dangerous) that the non-return valve into the shower body are operating. I've taken out the filters and they're clean. I fit the new cartridge and there's no flow from the hot even with the cold isolated.
Having re-read the installation instructions sent with the shower it simply states to make sure the cartridge is in the closed position, to grease the rubber seals with some silicon grease then fit.
Does anyone know if you need to insert the cartridge at a particular orientation. it appears circular but perhaps it's got to be aligned in a certain way??
I'd welcome any advice
Many thanks
Many thanks
