Okay so I promise the answer tothis thread isn't as simple as bleading the rads!
Having balanced my rads and installed a auto pump which delivers a constant pressure on the head, I now get my bedroom rad that gurgles.
There is definately no air in the system and the noise appears to be like a bursting of water throught the valve as pressure behind the valve builds up.
The valves on both sides of the rads are those fitted with the tr4 thermstatic heads. I aquired a resetting key from drayton which gives six flow setting through the valves. I must admit this staged adjustment doesn't beat a fully manual lockshield valve as the balancing is limited in it's precision according to these six settings.
Is this as simple as a faulty valve?
