Guttering
10 Jul 2016
Hello. The guttering at the back of a little part of the back has seen better days. TBH I don’t fancy painting it and would rather replace. Would anyone know what I would need in terms of actual parts for this? Was going to give it a shot myself and call in a plumber once I mess it up! Thanks.
If it’s any help it’s called a running outlet.....you may find the original make embossed in the plastic somewhere to find a replacement.
They clip into place but it’s much easier if the plastic is warm!
John :)
Thanks if I take the picture I posted to b and q could they tell me what bits I need exactly?
What part do you want to replace, exactly?
Bq = F all help, theyre cheap for a reason.
Much better to identify the make, and then head to a builders merchants I think.....Marley, Osma and Floplast are common but there are many others.
There will be some identification on the outlet so best to remove it, clean it up and see what’s there.
At least, yours seems to fit well - apart from the colour- so you may be in luck. Different makes rarely fit together well.
John :)
Yeah they’re shocking. It’s the whole thing in red and also the guttering at the top
Schrayder is right though....you’ll get naff all help from B&Q. Dismount the outlet and head for a builders merchant - someone will recognise it.
John :)
