gym bar help
25 Aug 2012
Hiya to all,
Ok im making a gymnastic bar an here is what i've bought:
(ideally would like to build it indoors but a reckon to complicated)
2 metpost in which will hold 75mm x 75mm x 1.8m wooden fence posts.
For the bar,im using a (1.8M x 40mm Dia) tree pole.
Can anyone help with regards to making it fit through the posts and what measurements /distance apart i use so its solid, or if theres other techniques to use for attaching the pole to them.
Only have a 32mm flat drill bit which was the biggest one they sold in BQ.
I no guys your telling me to take it back total wrong tool to use haha
your supports need to be no bigger even smaller than the crossbar dependant on span
try compressing a bit off 44x44 it will support several dozen kg
the same bit off wood will snap on a span of say 300mm with the same load
of course the frame has to support loads in several directions but a thinner structure with a bit off triangulation will serve you better than metposts and heavy timber
im only 8st i wont snap it lol an its more for strengh training not for what the pro's do on them.
oh well thanks for taking time to reply x
in general you can make it more athestically pleasing less bulky with a bit off triangulation and bracing
have you got a link to a commercial one so we can suggest the best way to make it practical inexpensive and pleasing to the eye :shock:
1.8m seems a little on the short side.? My ten year old foster child can reach to 2m's and you need to be off the floor to use?
ayesha17";p="2493244 said:
Hiya to all,
job complete ! thanks to the couple who took the time to give me a negative approach on the topic haha
