Gyproc skim coat over joint compound?
28 Aug 2020
Ireland
Someone told me that you can’t actually use the gyproc Skimcoat stuff over top of the gyproc joint compound (multipurpose) because it’s sort of incompatible, something about the skimcoat being a veneer plaster and putting over joint compound is wrong. He said skim the whole surface with joint compound instead!
is this correct??
I should also mention my substrate is gyproc plasterboard
you could skim the whole surface with jointing compound but it wont be a good finish and you will have to sand it back.
i rang gyproc and the technical advisor said absolutely no issue putting gyproc skimcoat over gyproc joint filler multipurpose. he also gave me a step by step walkthrough of using the skimcoat plaster, said its a better option than rolling on thinned out joint filler as the skim coat
Do you sand the joint filler back to a perfect level 4 finish before skimcoat? What level of imperfection can be left before skimcoat layers
Ok so I had good go of this yeasterday. Skimcoat. Tricky business
My feeling is that it’s not the worst result for a first try at the process but there are still multiple spots that couldn’t get perfect before it starting setting.
I know best option was to get someone in who is an expert but I just wanted to try.
anyway, the question is now how do I fix the few ‘blemishes’ or little spots of recess after it’s set/still drying? Please don’t tell me it has
To be another skim coat. Is there something I can fill with and then sand? Can you smooth out some of those spots with new plaster or need something special?
