- Joined
- 1 Sep 2022
- Messages
- 7
- Reaction score
- 0
- Country
I had a substantial leak in my 1st floor flat. I am doing the remedial work myself under insurance. After lifting some flooring I have discovered 2 layers of 12mm plasterboard under the chipboard which is saturated and has spread quite far including under partitions. Its turning into a nightmare! I was expecting to just replace the worst effected chipboard which wasn't that substantial.
All the partitions are built on this floor obviously. It's easy enough to cut it all out but it really has to come out from under the partitions as I can't see it drying out or having the same properties any more, it just crumbles. Just the chipboard and it would have been OK.
Will it be possible to remove it all from under the partition without taking that down?
No way I'm putting plasterboard back in. It was probably for a combination of sound and fire proofing. Will 2 layers of 22mm chipboard be OK?
