Hi all
This is an excellent forum that I have gained many good tips from. That said, I can't seem to find anything relating to my particular problem - probably not looking hard enough!
Anyway, I would appreciate some advice on this problem please.
I have a boiler specifically for hot water situated in the kitchen of my flat. There is no header tank as it is connected directly to the main water feed. Open the taps and it fires up no problem with excellent heat and good pressure. It is a Chaffateaux (Sp?) Corvec Brittoney IIa.
It is also connected to my bathroom which is about 7m from the boiler and the shower head which is directly connected to the baths mixer tap set.
I have always had to turn the hot on fully in the shower and then crack the cold about half a turn to get a good temperature. This was fine until a few weeks ago.
Now I open the hot water tap fully and get a good temperature (I can't put my hand under it), but when I crack the cold open it reduces the pressure going through the boiler and shuts down the heat.
I have de-scaled the pipework from the boiler to the shower head, and the heat exchanger in the boiler. The boiler diaphram was replaced about 2 months ago. The problem is that it is intermittent. Some times in the evening I have a great shower with loads of control, but other times in the evening, and mostly (if not all) in the mornings it is crap.
I also have one of those AquaMag things on the cold feed into the boiler. (My mother bought it, but never had it fitted - honest) this has been on for about 3 months as I live in a hard water area - Portsmouth.
Any suggestions would be greatly received.
Many thanks
Huw
Many thanks
Huw
