Hallway spotlights
29 Mar 2013
West Midlands
Am looking at installing 3 mains voltage recessed spotlights in hallway at our home. Should I be concerned about the heat rising up to floorboards,is there a minimum depth the joists need to be. Any advice would be welcome,just want no worry about my house catching fire!! :roll:
Requirements may vary for different manufacturers.
Do you have a particular fitting in mind? - there will be instrucions in the box, but if you want to know before you purchase, you could google for installation notes
Are you planning on using 3 because your hallway is huge, or because, being spotlights, 1 won't work very well?
If you have a cat, yes.
You should also worry about your electricity bills.
The instructions for the lights will tell you.
Don't try and light your hallway with recessed spotlights.
If you want spotlights then you install spotlights. Don't listen to ban-all-sheds. Hes never seen a proper spot light installation, and has a real mis conception as to how good they really are.
Have a look at LED spotlights. They are very cheap to run, they run virtually cold so there are much fewer issues with heat, and they are virtually maintenence free. Just fit and forget.
The hallway is fairly long to be fair and the main entrance to house is on side of house,it's fairly dim to be fair I have 3 in landing and think it would look odd if there was 3 upstairs andonly1 or 2 upstairs. All advice and opinions are welcome be they negative or positive ( no pun intended) :P
Au contraire.
You keep telling me how good they really are when you use lots of them.
And that is exactly what is wrong with them, and every time you tell me how well they work when you use lots of them you are proving that I am right and you are wrong.
