Hi
This concerns two issues.
Firstly, my husband has discovered that for the kitchen ceiling halogen lights, the electrician has used the daisy chain method but to connect the supply for the original ceiling rose to the wire supplying the halogen lights, he has simply used a light connector strip. Is this safe and correct? I'd have thought there should be a junction box?
Secondly, we discovered this because my husband is trying to wire up the undercabinet lights to a two gangway switch. One switch to supply the lights in the ceiling, the other to the unit lights. Presently, the unit lights are plugged into a socket. We were going to take a spur down from the junction box to supply the unit lights, but are stuck as there isn't one for the ceiling lights! Any ideas? Or should we just call it quits and call an electrician?!
Thanks!!
Thanks!!
