I have a problem with my Halstead Finest Gold boiler as I see many others have on here. The problem is that the boiler lockout light comes on about 2 or 3 seconds after the boiler has fired up shutting down the boiler. After using the reset switch the same problem reoccurs after about 2 or 3 attempts (sometimes a lot more) the boiler runs for a while. However, after about 5 min or so the boiler consistently seems to shut down (with no lockout light this time) and won’t run at all until it has been turned off for quite some time. Needless to say this makes trying to use the boiler at all a pointless task particularly since that while DHW does come out hot for the time the boiler is running the CH hardly seems to heat up at all since the CH flow pipe from the boiler seems to be cool even though the burner appears to be firing.
I have already had a lot of work done on the boiler recently and this is the problem I have been left with which is not all too dissimilar to the original problem i.e. the boiler kept shutting off providing insufficient DHW or did not start up at all. The guy I called out replaced the Fan, Thermistors, PCB board and suggested replacing the overheat Thermostat at which point I decided he did not really know what was wrong and was just clutching at straws with a new story as to what was wrong each time! To test my theory I replaced the overheat Thermostat myself a simple job as it turns out and surprise, surprise the same fault continued to persist, I had just saved myself £50 labour charge as a result. I am of course dubious now whether any of the above really needed fixing in the first place but of course proving that is another matter. It appears to me that just because someone is Corgi registered it is no indication that they are actually competent or not. I have seen other stories on here of Corgi registered people that seem to be more clueless than the customers they are supposed to be helping. I do not think that the guy I had out was dodgy since it would not have been worthwhile the 10+ times he came out compared to the labour he charged. However, to avoid wasting more money I don’t really have I would be grateful if anyone has any ideas as to what the problem may be ?![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
