Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
OK, I've just got off the phone with Mark, he has been down and replaced my DHW diaphragm (which had a hole in it) and the microswitch is now activating when the tap opens as expected, BUT , the DHW now overheats as it was doing before.
It comes on when tap opens, runs for 10 seconds, you can hear it starting to boil, then the overheat sensor kicks in and the burner cuts out.....for a couple of seconds....till it cools.... then it starts up again .....etc etc etc
Could there be a blockage somewhere ?
Could the heat exchanger be bunged up ?
Anyone got any ideas / or seen this before ?
OK ... Time to try removing the router from the equation....try unplugging the LAN cable from your router and plugging it straight into the laptops lan connector.
Set the desktops IP manually to 192.168.1.1
Set the laptop to obtain automatically ( on Local Area Conn)
Can you ping each other, can you see both in network neighbourhood.
Set the laptops IP manually to 192.168.1.1 (on Local Area Conn)
Set the desktop to obtain automatically
