I'm fitting a new handrail up my stairs.
I understand the minimum height is 900mm however am unclear as to where this is measured from? If it is measured from the rear of each step then the handrail will be much lower than if it is measured from the front of each step. Also is this height to the top or bottom of the actual handrail?
Secondly, I'm fitting a stainless steel handrail 4m in length. How many brackets would people recommend I use to mount this, and what size of screws and plugs?
