I've hung lining paper a number of times, but never anything above 1000. Anyone got any good bits of advice for hanging thicker grades of lining paper?
The walls were in pretty bad shape, but I've patched them up, sanding any bumps and lumps and they're pretty smooth all round - still awful for painting, hence the reason I am using lining paper.
One of the important questions I wanted to ask is applying adhesive. I am using Wickes (UK DIY store) paper paste (this is all they stocked). Should I make a thick mix?
When applying to the paper whats the best time to set the paper aside after applying the paper paste, and how many coats? Should I do one coat of paste, set it aside, and apply another before hanging?
I've also read somewhere that if you have to fill in a number of large holes you should apply PVA to the walls prior to hanging as it will stop the patched areas from sucking in the paste and will give a better stick.
I think that's about it. Any other advice you can throw in would be great.
Cheers
Cheers
